Hello all,
From looking at my tear down pics and wiring diagrams for my SS12, I'm seeing a chassis ground. Seeing how I've coated everything with rust reformer, primer, and several coats of paint, am I good to just ground the system to the battery tray(after scraping to metal and using a star washer), or would I be better off going directly to the frame using the same method?
Should I go out and get a dedicated grounding strap or will soldered terminals work fine?
I'm not gonna lie, these older systems are new to me.
Should I do the same to the grounding side of the voltage regulator?
How about the engine mounting bolts?
As I piece the parts of the frame back together, should I make sure there is continuity between all sections?
I guess I just want to do it right the first time instead of chasing electrical ghosts in the future.
I'm used to solenoids...
Thanks,
bobcat2
Thanks,
bobcat2
