Hope the rebuild goes good for you Noel.
No other major damage to one that blew ? (block, cylinder)
A little piece broke out of the bottom of the cylinder Bill. And I don’t think it would bother it if it was rebuilt.
That snow looks like it set up good. Maybe you could cut it into squares and build an Igloo.Just starting on my deck Gary. Shoulda shoulda done it yesterday !!!! Warmed up over nite and its soaking wet. Like shoveling stones. And the snowblower won’t do nuthin to move it. Just drives up on top. And I knew and know better. Shoulda done it yesterday. Any way the temperature is dropping so it will freeze. Be easier to shovel and blower might work. Trouble will be the stuff on the bottom.
Got every thing else done.
That snow looks like it set up good. Maybe you could cut it into squares and build an Igloo.When that freezes up you'll need a stump grinder to remove it.
Pace yourself and take lots of coffee breaks.I am cutting it into squares to shovel it off, but they are not square when they hit the ground, hehe. And no use trying the blower, still wouldn't move it.
Kinda like a light bulb Doug. Ya never know when it going to go out. Hehe.
Any way. Have a kit ordered for a 14hp engine that we have. But be three weeks before it gets here. We have some 14’s that have short crankshafts. Must of been generator engines or some different application. May take the 12 crank and put it in one of those 14’s and see if that will run for the time being.
Any way. Will still be looking for a 16 hp k341 engine. Ya need hp to blow snow in my experience. Ya the other smaller engines have there place. Yard work, stuff like that. Snow blowing. You need hp. And in my case, if I had a 20 hp engine to put on the Ford. That’s what I’d do. I believe that would be the answer. The Case 224, 14 hp k321 will cut grass like any thing and not lose revs. Had it out in the snow yesterday, with the 4’ snowthrower, ya way under powered. Just my take on it.
About how much money would that engine be Doug, you put in the MF 12. Don’t know if they make a 15 hp or not. I might consider that the next time the light bulb goes out. Hehe.
The Ford has a 42” snow blower. It should have a 17.5 hp motor to run it. At a minimum.
That little chunk out of bottom of cylinders won't hurt a thing. Just use a fine file to chamfer the edge of it a little
That was a brain-dead question, wasn't it! Sorry about that, Noel!Ya that end Doug.
