Brinly 12 inch moldboard share availability
Cottonpicker
New Member
I can not find a source for a 12 inch Brinly plow share. My John Deere dealer can no longer order them. I have called Brinly and was informed they have discontinued making the 12 inch share. They recommended using the 10 inch share on the 12 inch plow, ???
Does anyone know of a source for the correct part or have an acceptable solution?
Not surprised you can’t get one from Brinly.
A few years back I bought the next to last 12” plow share that Brinly had . I should have bought both. Was told then, there would be no more 12” plow shares.
Replaced mine and used it at Daniels last plow day.
Still have the old one and someday am going to redo the tip,,,,,,maybe someday.
I don’t have a 10” to compare it to, to see how it would bolt up.
But sounds as if that is your only option for a new one.
Thanks for the info. Remember Ball Hollow Plow Day 2014 (I think that was the year) and a Brinly 10 inch plow was given away, well I won that plow and used it behind my AC and Cub Cadet until I moved up to 3- point John Deeres. I will see if that share will fit the 12 inch plow and if so will order a new one.
Ironically I just talked to Mike (MRMD) two days ago and may reach out to him about refurbishing a 12 inch share for me if the 10 inch does not work out.
