Case 224 is on the trailer.
So the Case 224 might make it to the old wood splitter tomorrow. I’ve been wanting to hook this Case to the wood splitter for a while now and each time I get close to doing that, something changes and it gets put off. Sooo, I cut the grass at home tonite and when finished I put it on the trailer. So that’s a step toward getting it hooked to the splitter.
The splitter used to be hooked to my TEA20 Ferguson tractor. It would split most any thing but was slow to move. Ferguson pump is about 2 to 3 gpm flow. So I’ve been curious how this Case tractor with 8 gpm runs it. Since I got the tractor, almost two years ago now, I’ve been wanting to hook the Case to the splitter.
Tomorrow maybe the day.
Drive oil in the pump and hydraulic motor took a while to cool today after cutting the grass, got up to 132F, which is normal for it, but it was hotter today than the other days I was testing it. 81F with a feels like 95F here today.
So will see what happens tomorrow.
How fast did you have to run the old Ford to make the splitter work the way you wanted ?
Curious about the Case too.
Mostly full throttle Bill. About 2200 to 2400 rpm’s
So will see what Case does. I have a rpm gauge on the Case.
I hoping for 3000 rpm’s with the Case. And be twice as fast as the Ferguson was splitting.
