I wish they made it like John Deere where a car battery could be installed.I get the largest cca battery to fill in the hole that I can. Farm and fleet has 2 grades of gt batteries, one is like 195 cca, the other is 335 cca and there's only$5 or $7 difference. Same size as each other, too
My 1512 Cub Diesel is that same way. Largest Interstate is about 350CCA and that is not enough in cold weather. Have to use a booster on it. Next step up is a car battery and physically to large to fit.I wish they made it like John Deere where a car battery could be installed.
They are skinny enough but most are too tall in most tractors I tried.Some older Honda Civic car battery’s will fit, some tractors. About the same length and width, but taller. Have 500 cca
I like my uncle's I used it alot before he took it home and let it get rained on.I have a 1650 with snow thrower I got with no engine. Working on a Kohler CH16, like OEM, but run into a snag with rebuilding it. Hope to get it going to same another GT. Otherwise the thrower will go on my 1512.
My uncle just got a bunch from a friend who was changing them out of his motorcycle once a month cause he thought they was bad but it was his charging system. Going to charge them and give them a try.Anyone try a motorcycle battery?
