I still have this thing, 6yrs now and the batteries are still good, the main thing I have used this for is plowing snow off the driveway, now that I have the GE tractors it just sits around and takes up space, the GE tractors are better at pushing snow, there heavier.
So what to do with it, well I tried the GE tractor at tractor pulling and they don't do so good, the drive belts slips, if you get the belts so they grip then I find it doesn't have enough power, moves too slow. Motor is rated at 1.2hp.
So I tried ET2 at the pulls and it does better, has more power and moves faster. It's motor is rated 2hp continuous, 10hp peak.
So I switched the 2hp motor for a 6hp motor and it does even better, the heaver the class the better it does, but moves a little slower than with the 2hp.
So I changed the gear ratio between the motor and trany to speed it up a bit, I run in 4th/top gear at the pulls.
Problem is the 6hp motor needs 48volts and I only have 36volts, so I'm down on power and rpm but I'm right in the middle of the pack at the pulls.
Need to get a 4th battery in it.
At 36volts rpm=2500. At 48volts rpm=3500.
Motor rated 6hp continuous and 15hp peak at 48volts
So I have decided to use ET2 for tractor pulling and see how good I can get it to do. Got to do something with it.
Current pictures
Current pictures
