Figured this is more of an attachment. Anywho, I had made a basket for some cast window weights. At 7 lbs. each, takes a few to do any good. I had made an extra pair of my lead suitcase weights and thought this would be a good place to use them.
I've been working on this as I need to take Alice apart and weld in a brace to the main framework. I took the mower mule drive off the other FF/20 as I wanted to make this mount work there.
Started fabrication of some angle iron to fit where the mule drive goes.
With that done, I made up a couple uprights and a 5/8" bar across for the weights to attach to. I made this big enough I can put all 4 on, but at 40 lbs. each, I'll probably stay at 2.
I got the mount finalized this morning and gave it a coat of semi-gloss black. It's drying now and I'll get a pic when it ready to mount.
