Wanted FOUND!!! 1975 or 1976 Briggs 11 HP
cootertom
Well-Known Member
Possible shipped by Fastenal.
I have a good motor but a couple of magnets came off the flywheel and took out the stator. I haven't found any numbers on the motor and I was told there was 3 different ones on the 11 HP that year.
dodge trucker
your header says wanted but your 1st reply looks and sounds like "for sale" instead/ the engine in the pix looks newer than mid 70s.
if this is a "wanted" ad, why do you specify you want an engine made only one of those 2 years? They made that 11hp for many years.
something that trips me up is that within a given engine brand/series there are so many versions... crank length/diameter configurations, fixed throttle, several types of variable speed throttle, etc.
cootertom
Well-Known Member
Trying to keep the garden tractor original and it is a 1976. The picture is for a general reference. The motor on it had NO numbers on it anywhere.
KennyP
Alice's Creator
You can change the title to Found yourself. I went ahead and did it!
