Got the Sotah Bever out and up to the shop yesterday. Time for a full service before it goes to work this spring. Oil change & filter, topped off the trans-hydraulic oil. Greased the tractor and then the loader. Found one zirk that would not take grease. The pivot pin on the top loader arm at the back. Hard to get to but found it is one on the drive in zerks. Has grease on the pin I can see sliding the arm side to side so will go for a while yet. Will probably have to lift both arms up out of the frame to get at that zerk to replace it. Probably go with a threaded zerk. All that crawling around, bending, twisting, et. I wasn't used to could really fell it last night. 20° colder and NW wind today so might just stay inside today. Might be a shopping day as we need about a dozen bags of top soild and half dozen bags of potting soild for some flowers that need moved away from the house.
