Hi all, installed new blades on the deck checked it over good greased the center spindle and got it under the tractor and installed. Went pretty good for the first time its heavy so I used a prybar and blocked it up to grt it onto the hitch etc. Run the PK out tried the deck the PTO engaged and the deck sounded good so gave it a short test try the grass had so much dew this morning it looked like as much water as grass was coming out so just did 2 rounds to see how it was cutting it was good, will mow some this afternoon when the grass dries.
