Those are nice. I've seen them, but never as a list like that.
Hill mower holding up ok?
Well done they look good. Would love to see a few close ups of the front bucket set up.
I really like that mid mount blade.
The hill mower works good, but isn't quite wide enough. I have an old 38 inch deck that I am going to mess with and try and mount an engine on it. The trick is not to make it too heavy that you can't push it up the hill.
When you get to that 38" deck try going with 10 or 12" wheels. Makes a world of difference on easing up the pushing effort.
Nice looking equipment. Lot of those tow behind mowers around but I often wondered how they pick up those tire track with the weight of the tractor pushing the grass down. Have to use a high lift blade? I have pick up problems if I hit a wet spot with a center deck.
You run 2 cycle motors on that bank mower? Looks like a good place for a Lawn Boy.
My drag harrow I made a year ago. About to do some work on it to use it on the farmall cub so I can use it lift so I don't have to get off to clean it out.
