Home made attachments.
Just finished making this set of ridged harrows 4'2" wide and 3 rows of 11 tines 5" apart and each tine is 5" long , each row is 9" apartthe harrows are 1 inch wider than the tractor wheel base IMG_20181021_135359.jpg IMG_20181021_135424.jpg the tines are old tie spikes from a old rail line , found them on city curbside 5 yrs ago approx
Shane
Counterweight box made for category 0 3 points hitch which I also made an adapter to install on my JD 214. I can put whatever I have laying around, most of the time I use the concrete slabs that we use as walk ways in the garden
View attachment 6998View attachment 6999View attachment 7000
Also I made an adapter to install my custom engine hoist on my 3 points hitch, it also has a 2"x5/8" receiver for the draw bars I use on my cars. The draw bar you see in the last picture has a welded bolt on which I screw the ball of the size I want. The engine hoist will also fit in receivers at all 4 corners of the trailer I will build "soon", it's made to be able to rotate on the main shaft (round tube on square) with a locking bolt when used on the standalone base or on the tractor.
Sadly the engine hoist is already too heavy for the 1655's hydraulic, it struggles lifting it therefore I must lock the 3 points with chains or rest it on something. It is still quite useful!
View attachment 7004View attachment 7001View attachment 7002View attachment 7003
I have a tow bar on my manual engine hoist so I can tow it around. The same tow bar is shared with my cart. IMG_2805.JPGI liked the idea of hoist on rear of tractor but lift capacity rather limited. Hoist does need larger wheels, that mod is on my to do list.
