Home Made Yard Rake
KennyP
In memory of Alice's Creator
Made this up a couple years ago. Decided it was time for some paint! Put it up on the saw horses to take it apart.
This is made using 35 tines from a hay rake! It's 54" wide and does a great job pulling twigs and such from the grass.
nice Kenny
How does.it work on gravel?
Brings the gravel back up to a point. If it's loose gravel, very good. Tine spacing is 1.5".
I got one side of the tines painted this morning. May be tomorrow before I can turn them over. I'm using Van Sickle IH Yellow on them.
Went out this morning and started putting the tines back in.
Here's how i get them in, start the bottom through the hole:
Then, work it down to the next bend:
Then, work it down to run back under the top and hook them in:
All in!
Got the top back on and it's ready to use!
That's a really cool attachment Kenny. If I only had a tractor with a suitable hitch! How does it handle rough terrain like drain field humps and tree roots exposed out of the ground just a bit? Maybe your yard isn't as bad as mine.
The tines will bounce over things if I don't have too much down pressure on them. I like it as a 3-point as the top link lets me adjust it to a more/less aggressive stance. Plus I can raise it pretty high to dump.
