Yes,,there is just too much gap for this not to be intentional. I will assemble it again with lots of lube and see if it will work without the worm gear binding. Initially I considered levelling the surface with Bondo to see if chute would work better. Bondo would be easy enough to remove if it is not a solution.They may have had an outward roll to the flange for water?
