I found this info from a manual my son got online... I can ask him to find more if u need.. but for now try this
Step 1
Relieve the hydraulic-system pressure before attempting to repair any leaks. Ensure the tractor engine is not running, since the engine usually operates the hydraulic pump.
Step 2
Securely tighten leaking hoses or tubing nuts.
Replace the hydraulic tubing or the cut or damaged hoses.
Leaking Components
Step 1
Reseal leaking fittings on hydraulic components. Unscrew the fitting from the component with a wrench. Remove and replace O-rings or other seals on the fitting. Then screw the fitting back onto the component.
Step 2
Replace the components you may be unable to reseal, such as the tractor's hydraulic pump.
Remove and reseal leaking lift cylinders or other hydraulic cylinders. You can usually purchase a seal kit for each cylinder -- containing every seal needed to rebuild the cylinder.
Tip
- If you find leaky hydraulic cylinders and you don't feel comfortable resealing them, replace them.
Warning
- Don't search for hydraulic leaks by feeling around with your hand. Pressurized fluid squirting through a pinhole can puncture the skin.
