IH 284 with the Roller
cjet69
Hooked the 284 to our small roller and pulled it over to the water supply. Filled the roller up and made a few passes in the pasture where the cattle had pock marked the ground. It makes it smoother where there is still enough moisture in the ground. Where its to dry may need some light discing to knock the tops off.
That's not a real small roller..! More than 50 gallon I'd say.
And you got duel wheels on the 284 ?
I measure it and it about 43" wide and 29" diameter. If the online calculator is right that puts it at about 123 gallons. Yes the tractor is running dual's in back and we run 26" x 12.00" - 12's that came off of our parts baler's on the front. The tractor weighs
about 2300 lbs and it floats pretty good with this setup. I put a pic of one area that I am rolling. You can see it gets plenty wet in the winter.
I measure it and it about 43" wide and 29" diameter. If the online calculator is right that puts it at about 123 gallons. Yes the tractor is running dual's in back and we run 26" x 12.00" - 12's that came off of our parts baler's. The tractor weight about 2300 lbs and it floats pretty good with this setup. I put a pic of one area that I am rolling. You can see it gets plenty wet in the winter.
Yea you can hire on with the road dept. with that roller
