Hey guys,
So it has been a year since this problem started and I am finally getting around to starting it. It has been a crazy year! Anyways, I have a 317 that started to leak hydro fluid as soon as I changed the fluid. I changed from ATF to low vis hyguard and bam leaks. Not sure if it was the change of fluid, or it was just its time to leak, but it started. At first I could not figure out where it was leaking from, but after cleaning it and carefully inspecting it I am 99.9% sure it is leaking from the gasket that holds to housings together. I made a little video to walk through it. But first, any advice, guidance, or other things I should think about would be GREATLY appreciated!
I was able to get the transmission out and on the bench, but I am stuck. I can't seem to get the housing apart. What am I missing? Any advice on getting it apart?
Also, is that a plastic film on the gasket going to the gear box?
