1986 JD 214
New to me in 2011 with an undefined 'engine rebuild'
The following info is provided as everyone will ask, but the information has no bearing on my ASK.
Last two years repairs
MY ASK
I've seen the videos, I've talked to Taryl, here's my ASK:
Reason for changing points:
Thank you
- New coil
- New condenser
- New plug wire
- New plug
- Valve lapping
- Valve gapping corrected to standard
- New carburetor
- Removed worn out original fuel pump and replaced with a Briggs pulse pump
- New gas line from tank
- Cleaned gas tank
- New deck belts
- Replaced rear deck sheave
- New Air Cleaner
MY ASK
- When new points are installed, and adjustment is set, so the gap is as wide as possible before rotating the flywheel, do l I rotate the flywheel looking for the widest points gap, then gap at 0.020, and adjust as necessary between 0.018 - 0.022 until engine runs properly under load?
- Old points were 12 years old
- Under load, the engine was running smoothly, but would not run at full power.
Thank you
