working on a 2016 Hustler (I think its 2016 if Im intrepreting their numbers right) only 11 hours on it from new. wouldn't start, even with a new battery/ would sputter when I dribbled gas in throat. so I have the carb off. pretty clean except for crustation in the very bottom of bowl. It has a weird plastic float/needle "carrier" Ive never seen before. 27hp Kawasucki twin. FX850V. I've looked at Jacks, PSEP, and 1 other place/ all they show is each gasket and Oring seperately. but somehow PSEP (Pats sm engine) in their "universal parts" section does show an OEM Kawi kit for this size engine. but when I put the whole number from the engine in, (look up "the other way") no "kit" comes up.... Individually they want $18 for the needle..... yikes. and each gasket and Oring is seperately listed.
anyone have any experience with tehse units? this is a first for me. Carb is a very basic unit..... glad the solenoid tested good, I tried getting it off last fall and didnt have a shinny enough wrench, tried to grab the solenoid body and just spun the case of it.... was hoping I didn't tear the wires off internally,,,,,, that would have been a $92 mistake.... it was a little gummed up though and a bit stiff though. ain't my machine so I cant really do the bypass.... (snip the tip) .
