Let's learn more about Hondas
_floater_
When I first came here most folks hadn't seen a Honda tractor. I hadn't either, but I've been really curious and have found quite a bit of info. I'm going to add to this thread when I'm not lazy and it will serve as an information source for current and future contributors.
I'll break it down into models starting with model 5518.
5518 Multi Purpose Tractor
5518 Snowblower
5518 56" Snow Blade
Specifications
General Specifications
ModelHonda H5518
Length2,190-2,370 mm (86.2-93.3 in)
Width1,070-1,125 mm (42.1-44.3 in)
Height1,235 mm (48.6 in)
Wheel base1,305 mm (51.4 in.)
Dry weight457.0-480.0 kg (1,008-1,058 lbs)
Front tires size20×7.0-12
Front tires pressure98 kPa (1.0 kg/cm2, 14 psi)
Rear tires size24.5×8.0-14
Rear tires pressure79 kPa (0.8 kg/cm2, 11.4 psi)
Fuel tank capacity9.0 l (2.38 US gal., 1.98 Imp gal.)
Battery12V-30AH
Engine
Engine modelHonda GX630
Displacement635 cm3 (38.7 cu-in)
Bore x stroke76.0 x 70.0 mm (3.0 x 2.8 in.)
Max. horsepower18.0 HP (13.2 kW) at 3,600 rpm
Max. torque46.1 Nm (4.7 kg·m, 34.0 ft·lb) at 2,500 rpm
CarburetorHorizontal type, butterfly valve
Cooling systemLiquid-cooling
Ignition systemCDI ignition
Lubricating systemForced oil by trochoid pump
Starting systemElectric starter
Stoping systemCut off the power supply to the CDI (Open)
Fuel usedUnleaded gasoline (octane number 86 or higher)
Spark plugNGK: BPR5ES-11 NIPPONDENSO: W16EPR-11
Oil typeHonda 4-stroke or an equivalent (SE or SF)
Recommended oilSAE 10W-40
Oil capacity (without filter changed)2.0 L (2.11 US qt, 1.76 Imp qt)
Oil capacity (with filter changed)2.3 L (2.43 US qt, 2.02 Imp qt)
Transmission
Gear typeSelective sliding 8 speeds forward and 4 speeds reverse transmission
Gear selections8 forward, 4 reverse
Groung speedsForward:
1 (L-1):
0.7 km/h (0.4 mph)
2 (H-1): 1.1 km/h (0.7 mph)
3 (L-2): 1.5 km/h (0.9 mph)
4 (H-2): 2.4 km/h (1.5 mph)
5 (L-3): 3.4 km/h (2.1 mph)
6 (H-3): 5.3 km/h (3.3 mph)
7 (L-4): 7.1 km/h (4.4 mph)
8 (H-4):11.1 km/h (6.9 mph)
Reverse:
1 (L-R1):
0.8 km/h (0.5 mph)
2 (H-R1): 1.4 km/h (0.7 mph)
3 (H-R2): 1.8 km/h (1.1 mph)
4 (H-R2): 2.8 km/h (1.7 mph)
Frame
BrakesMechanical leading-trailing shoe type brake (rear wheels)
SteeringPinion-and-sector four-wheel steering
Hydraulic system
Working pressure90 kg/cm2 (1,280 psi)
Pump typeGear pump
Oil capacity2.0 L (2.1 US. qt)
Honda Mighty 11 and Mighty 13 And Sub Models
(AKA Honda 1100 and Honda 1300 and Sub Models)
Mighty 11
Mighty 13
Specifications
No. of Cylinders1 cylinder(s)
Water-cooledNo
FuelPetrol
Performance: 11 HP
Rated RPM 3600 rpm
Regulated Rotations3800 rpm
4 Wheel DriveYes
Forward Transmission8 (4x2) gear
Rear Transmission4 (2x2) gear
Reversible DriveNo
Differential LockingYes
Independent Side BrakesYes
Length220 cm
Width93 cm
Height124 cm
Wheel Base121 cm
Weight405 kg
Front Gauge68 cm
Rear Gauge59 cm
Front Tire Size4.00-12
Rear Tire Size6.00-12
Adjustable Rear GaugeNo
Hidraulic PositioningNo
Rear Hitch2 point
Standard PTO ShaftYes
Rotary TillerYes(100 cm)
Year of manufacture1985
I think the “Mighty 11” and “Mighty 13” might differ slightly from the RT5000 and the H5013, they are sold I believe only over in Japan although I’ve seen a few in North America for sale. I’ve noticed that they seem to have 2 brake pedals (split brakes) not sure what other differences there are, but it seems like the Mighty 11/13 almost always are lacking a front lift like the RT5000 and H5013 have. Of course the RT5000 comes with front and rear lift as standard equipment and the H5013/H5518 with front lift standard and rear lift optional.
This is correct. Please add anything I'm missing.
Honda HF 2622
Overview (Italian)
Mowing Tall Overgrowth
Specifications
BrandHonda
Power Details4 stroke OHV V-twin Honda GXV660 688cc
TransmissionHydrostatic
Cutting Width122 cm
Cutting Heights(7) 29 - 90 mm
Collector350 Litres
Fuel tank Capacity8.4 Litres
WheelsTyres - Front 15in x 6.00in - 6 / Rear 18in x 8.50in - 8
Noise Value - Sound Power Level dB(A)105
Weight254 kg
Warranty5 Years Domestic - 1 Year Commercial
Lawns up toOver 10000m2
Other FeaturesElectronic Grass Dump System
There was also the H6522 Honda, this was a step above the RT5000/H5013/H5518 series tractors and more of a compact tractor than a garden tractor. They used a 3 cylinder Honda diesel engine, bet you didn't even know Honda ever made diesels lol.
attachment.php
Ok. So the Honda tractors were a great machine. How come they stopped making them.
Noel.
I dont think it ever caught on for them. They sell a lot of push mowers.
I've seen one Honda tractor. My dads neighbor had one when I was growing up. It wasnt one of these garden tractors. It was a lawn tractor. Looks like the hot 3813. It was liquid cooled. I remember him working on it constantly and complaining about it.
These heavy duty ones look pretty nice. If I ever see one pop up on craigslist I might have to take a look.
Noel.
The story goes they couldn't produce this type of machine and compete with the flood of cheap brands that hit the market in the 80's and 90's.
Seems logical, as you can see, they loaded their machines with options.
There is also no evidence that these were necessarily considered "great machines."
I think what it came down to was price more than anything, and let’s face it, small diesel tractors were getting cheaper and more popular at the time. I guess they were never a big seller for them so that was that.
attachment.php
Honda got involved with Indy car racing and put their resources there. I don't follow Indy racing so have no clue how that panned out for them. Motorcycles and 4 wheelers made them their $$$ for years.
