Lately I noticed that my tractor's hood was not aligning properly on the tractor, especially the hole for the gas tank filler that was too much forward (or the tank was too much backward). I started observing if the hood was bent or the tank moved but all those were fine. Then I found my problem...
Lately I've been removing a lot of ice in my driveway, it's starting to thaw and I get huge water puddle near the road. I wanted to get my 4 drains in the corners of my driveway where it meets the road clear, I only managed to keep one of them clear this winter. I used the 54" JD blade on my quick hitch for this and sometimes I was quite a bit abusive with it, I removed some big chunks that were up to 10cm/4" thick, lets say it takes quite a bit of momentum to remove those.
Also I had to move the tractor to a friend's place to free his trailer from the snow with the snowblower.. the trailer I had in hand to carry the tractor was not long enough and I had to move it with the blower "hanging" on the tractor (facing backward in the trailer). At one point on the road I hit a ditch in the road which is fine for a car but not for my tractor and it (trailer and tractor) jumped quite a lot... in fact the trailer detached from my car because the coupler was worn out... No damage to anything, I was lucky on that and now the trailer has a new coupler.
I don't know what was the worse, the ice ripping or the jump on the road but I discovered that the tractor's frame is now bent ):
Today I am going to a friend's garage and he owns a small loader which I plan on using with a bottle jack as a press. I will place my frame on wood and push from the loader's rear counterweight down on my frame to get it back straight... At least that's my plan, we'll see how it goes.
Yesterday after work I stripped down my tractor. Took me a bit under 2 hours to get the frame stripped down and in my car.
At this point without the steering "A-frame" I was able to get a good look at the "damages". It bent exactly where the frame gets wider for the engine, that is really a weak point for this frame.
"And we got separation of the rear end after 1 hour and 47 minutes after the start of the tear down"
I can tell that "uncompressed", a tractor uses a lot of space!
For next year I will look into adding a "frame" that will join from low on the front hitch to the rear axle where the 3 points hitch is attached to the tractor. This should prevent "torque" from going through the tractor's frame when I am not reasonable.
