I got this welder used about 20 years ago & never done anything to it but use it. I did this awhile back & seen Kenny's round top project the other day so I thought I would encourage those with these old gems to revive them. All I did was the typical take a part, clean, & inspect for loose connections. I sanded all the paint off then primed with Rust oleum gray & finish coat with Rust oleum Sun Rise Red. This had the factory wheels & single handle. Since I will be putting this under my welding table I will be leaving these off so it will fit.
The face plate had some years of dirt & over spray so I cleaned it with some Dawn dish detergent, warm water & 000 steel wool. Then I sprayed it using Rust oleum clear.
