Our lawn is looking bad with all of he grass that has built up on it from being thrown out from the mower deck.
So I have decided to put a mulching kit on my mower.
JD makes this insert to enclose the three mower blades but it cost $237 plus the cost of the blades.
It is a nice insert made out of heavy duty plastic but the cost is more then I can justify so I decided close the blades in with metal strips.
First I held a marker at the end of the blades and made a line on the inside of the mower deck where the end of the blades run.
Then I cut a strip out of a piece of poster board and fit it to the shape of the deck.
The pattern is transferred to the metal.
And the metal is cut with a plasma cutter.
I clamped the piece in a vice and smoothed the edges down with a grinder.
The piece is run thru the roller to form the curve in it.
Here are the first two panels welded in place.
The rest of the panels are made up and welded in place to enclose all three blades.
Then I started forming a piece of 3/8 steel rod around the outside to add some strength to the steel panels.
The steel rod is welded in place.
The metal work on the underside of the deck is finished and primed.
The mulching blades are mounted on the deck.
The spots where the welding burned the paint on the outside of the deck are sanded down and painted to finish the deck.
The
The
