Need MF 7 mowing deck repair help
Anybody ever fix one of these. Need ideas. The couplers are worn along with the middle shaft and gear box shafts. If mowing heavy grass around the house, the shafts/couplers slip, then the blades jam up. This deck is timed so the blades don’t hit as they go around. Not offset , one in front of the other a bit, so they don’t hit.
Looking for ideas to fix. Have not checked yet to see if parts available. But when I checked years ago they were expensive. May not be available now ?
If I recall correctly, those were splined.
I have seen a lot of them welded over the years, I have seen a few that are welded on one side and shear pins on the other.
If they aren't wobbled too bad, I would probably pin them. you need to take it apart to change the belt, but there's no reason that it can't be a semi-solid connection.
Yes splined. Couldn’t think of that word. Hehe.
Can’t weld on the gear box side. No room.
They are hardened pieces. So how does one drill them.
If I drilled them, I would offset them like a universal.
