A number of years ago I built this CC 149 dump truck. The Kohler engine was getting noisy and tired. It would set for long periods of time and when I needed it the battery would be dead. 6.5 HP should be plenty for just hauling things around the yard.
The Predator engines seem to have a good reputation so the decision was made to do a swap. These engines are on sale now for $97. The first problem is the Kohler drives the tractor from the recoil side of the engine. I wanted to keep the recoil on the Predator so a battery wouldn't be needed. To do this the engine will be facing the opposite way and the shaft to the hydro will pass under the engine. I wanted the engine. mount, and shaft to be one unit that could be removed from the tractor with six bolts. Three on each side. This would allow the original engine to be reinstalled at a later date if need be.
A coupler was machined so the extended shaft could pass under the mount. It is supported by two pillow blocks and will be coupled to the engine via a #40 roller chain. The mount holes were slotted on the mill so chain tension could be adjusted by sliding the engine.
It was necessary to purchase an aftermarket air filter assembly so the hood wouldn't have to be altered. Also a different exhaust system will be fabricated. This is how it will look with the hood in the closed position.
Next week I'm hoping to finish this up.
