Sheet Metal Work
Lily'sDad
GMC, They Said
Sheet metal novice here.
I am making a round bird house and decided to put a conical metal roof on it. I made a pattern and cut the roof out of 22 ga. steel. Now I have realized that there is no way to roll it to shape by hand. Am I going to have to take it to a sheet metal shop??? Notice that the left side has a tab to overlap. I am including a photo of the flat piece.
larrybl
Looks like your cutting skills are good. Could you slice it into sections and rivet them together in the circular shape?
Texas Horses Hogs and Deeres
Administrator
You should be able to pull it together. You may have to kind of form it over the edge of your workbench to help the outside diameter to come together. Use the photo that Larry sent back to get an idea of what the sections will look like.
Arti
While 22 Gauge is fairly heavy if you get someone to help you should be able to pull on the outside edges and get it to come together, If you are making more of these I would suggest 28 Ga. Heavy enough to withstand some use and still easy to shape.
