Simplicity 7112H
Great mower for a suburban lot with the 42” deck.
Cat hit the nail on the head. No mower will make you lawn look as nice as a Simplicity deck. Yours being a hydro is a plus also. My wife would always comment about how nice the lawn looked after mowing with the 7117.
I think it is the rollers that do the trick.
They make the striping for sure. Besides that the lawn looked like it was cut with a laser. I think that had to do with how deep the deck was and the fact that it was following the ground not the tractor.
The best grass cutter I have owned was my Homelite T15. (AC 416/Simplicity 3415 clone)
It didn’t stripe as well as my current Simplicity ZTR, but it cut better.
Your right Aaron. The MF 7 deck cuts great and just fans out the grass clippings, no windrows or clumps out out that deck. And quiet, doesn't sound like a airplane ready for lift off.
Another one great cutting tractor/ deck is a LT81 Ford. Cuts just like the MF 7 but 36” wide, I think. Have not had it running in a lot of years.
And this one. It’s a great cutter too. Nice easy steering.
My AC 416S does a great job, just to big for my yard.
Kenny. I just looked up your AC 416S on tractor data. Is the shuttle shifter for forward and reverse. Different sort of set up. Never had a AC, so don’t know much about them.
Yes, nearly like a hydro as you can set speed with out moving the throttle.
I have a 3415S and I don't thing it is quite as responsive as the hydros but then I haven't used it very much.
