Small impact drivers = urgghhhh
Pig
Not sure how you all feel about small impact drivers, but I cringe whenever I see videos where a small impact driver gets used to tighten small screws on automotive/equipment jobs. :mad:
I only ever use impact drivers to loosen larger nuts/bolts, never to tighten them. Use a normal hand tools or a torque wrench for that.
Although I do have a hand-held, battery operated driver that I use for large quantity jobs, such as fencing (wood screws), etc.
It's fast becoming a pet-peeve of mine...
oh, it's not that bad, really. Just toss on thread locker first on the screws, then impact till your socks pop off.
:thumbs:
I use the basic B+D cordless to turn the screws. I turn the setting to 10 or 20, depending on what the application is. B+D are wimpy so over tightening screws or bolts would be a real chore for the drill.
You talking battery powered drill like things or are you talking a hand held block with a bit on the end that you got with a hammer to "shock" a bolt loose? Those I use to remove (usually rounded Phillips headed fasteners) never to tighten.
The hand held thing you hit with a hammer is what was always told to me was an "impact driver"
