Some thing I found the other day while I had my mad scientist hat on. I decide to check the ohms in the copper core of the H10C plug that was in the John Deere, which I'm having trouble with. I tested from where the spark plug wire connects to the plug, to the electrode where the spark jumps to ground. I am not an ohms expert or do I know what an ohms measurement means, other than a low reading is normally good for continuity. So the old plug measured 3.8 ohms. I had bought a new H10C plug the other day and measured it. It was 0.5 ohms. So would the difference be a big deal or not. The JD was having missing fits at full throttle under load, but not every time load was applied. Would that old H10C plug cause the fit. Another thing my genius mind, hehe, figured is, that the copper core in the spark plug, would it gain resistance over time, because of age, heat and electricity flowing through the copper core. Would any of this make any sense ?
Thanks for your wisdom on this problem and my thoughts.
