Stage-3
Body Removal
1) Remove the reverse pedal by releasing the barb that locks the plastic pedal on to the steel lever,
Pry up here with a straight blade screw driver on one of these, Or one of the nylon tools like I'm using,
Wiggle the plastic pedal off by prying just enough, not too much, it is plastic and can break with too much force.
2) Remove rubber hand grip from the mower deck height adjuster arm. It should twist off like a bicycle hand grip. (It shouldn’t be glued, if it is, the handle can be removed once the spring tension is released by a cargo strap or the like, then by removing a quick clip on the actuall lever)
And here,
3) With the handle in place, we need to hold the spring tension on the lever in place, this will help in the re-assembly section.
This can be done with a cargo strap, or anything that can safly lock the lever in place. The deck is in the neighborhood of 100lbs and these two springs are the counter weight to that so be aware, what you use will need to hold approximately a 100lbs. (I would not recommend bungee cords)
I have used a cargo strap very successfully (In the thread Beware Husqvarna the build part 2), so this time I will use something also common to home owners just to prove the point, what is common can work. I used common house wire scrap like this,
Test it’s hold before moving on, very important.
In the end, if it doesn't hold, but slowly slips like wire can do, don’t panic, when we get ready to put the body back on, a cargo strap can be used to put it back in place.
4) Lift/push operator seat forward, this wire needs to be out of the way,
Stage-3, Continued on the next reply...
Body Removal
And here,
