The MITSUBISHI - SATOH TRACTOR INFORMATION, PARTS, AND SUPPORT
Je possède un manuel des pièces détachées original pour Satoh S370 et S370D dans le carnet d'origine. 274 pages recto verso, donc un peu volumineuses à copier. Si vous avez besoin d'une pièce, indiquez-moi laquelle ; je la trouverai pour vous et vous communiquerai la référence OEM.
Bonjour Chieffan,
En fait, je suis en train de reconditionner one Beaver in North of France, i have all the manuals except the parts one.. Since 2022, did you numerise your catalogue? Otherwise, i'm looking for the speed shifter boot and the transmissions seals reference..
Thank you in advance and have a Nice day ✌
I had the same issue with the lift not staying up, turned out the hydraulic fluid was way low. Topped it off and everything worked fine again.
And I’ve had decent luck finding replacement parts by checking what interchanges with older models. For a few things that didn’t show up under the OEM number, I crossed it with Case aftermarket parts and found an exact match that fit and worked fine. Some parts even came labeled differently but were the same specs.
Did you ever get the s750 manual figured out? Is it possible to get a copy? my neighbour has a stallion and wanted to find a manual for working on it....any help you can give would be great :)
I am new to Tractor fanatics. I've been looking for Satoh stallion information for years. Looking for a shop manual or wiring diagram. I would love to get a copy of that. I'm not good at computers/blogs so I hope I can find this again.
