No they were totally redesigned just about everything is different expect the differential and drop boxs but the differential has been flipped 180 cause the engine was turned 180 and mine has a hydro others have a 4 speed but the clutches a troublesomeAre the newer PKs the same as the old ones, under all that body work?
Ya you betcha keep telling yourself thatYour knees don't get near as stiff and cold if you jump off and turn the blade by hand.
Yes I remember that also even thought of it when installing it yesterday you are so right the first few times its kind of fun but it does get old by March.Ever take notice that the first one or two snows is fun. Then the other 3 4 5 6 7 8 9 ect ect ect... Suck.!
I remember last we were talking about how to pivot the snow blade and you came up with an idea. I took that idea and used as well... You can kinda see it in the picture below.
If you could keep the back of the tractor on the ground.Would be heavy as heck but the loader should left it with no problem.
Might work for roads but not so much for parking lots if it was wet snow.If you could keep the back of the tractor on the ground.
Did you get up before the sun course that's not too hard these days good to hear you had a good day, it was pretty nice here today all so got the Haban snowblower on the 73 PK and the cab installed tomorrow will get the chains installedGot the stalks all mowed today. Makes it a lot easier to work the soil in the spring.
Actually didn't get up till after nine, About 5 acres and able to do 2 rows at a time with a 5 foot brush hog. 3rd gear high range is about right for the Fordson. Makes for a nice afternoon on the tractor.Did you get up before the sun course that's not too hard these days good to hear you had a good day
