I bought this 1995 to finally chip up and shred shrub trimmings, Liked useing it so well started getting rid of the brush from cutting fire wood too. I am the 3d owner don't have any Idea how much was used by other owners. Fellow I bought it from used it for getting rid of trimmings from shrubs & fall leaves.
I replaced the 5 HP Tec. engine in 2017 because I kept haveing problem after problem with the Tec. engine.
The 6.5 HP Hemi Predator was a good choice for an engine. It very rarely slows diown no mater how much stuff I feed it.
But it is showing the age and work it has done in the past, the shredding grate is in ruff shape now. Yes you can buy replacements on Flea Bay but they want nearly as much as I paid for the machine.
Bought some steel bar stock, I am forming to reinforce both sides. Also some bar stock to go cross ways about every inch also to reinforce the screen.
If this reinforceing doesn't work I will bite the bullet and buy one from here and modify it to work for me. It is 100.00 plus less in cost than the Flea bay ones.
Al
Troy-Bilt Chipper .75 Discharge Screen (1766970E701)
www.chalmersindustries.com
Al
