For when Duck Tape just won't do;
Turns Out There's A Secret Use For WD-40 That Most People Never Knew Was Possible
And when you get that nasty old black grease on your hands that the best soaps don't wanna touch, spray WD40 on your hands and wring it in and the goop wipes right off!
Wow, I didn't know they carried such a line of stuff these days. After your post I looked it up. May have to try them out.I went to the box store to get some WD to clean tar off my truck. That's when I found that they have some different formulations now.
If I have gritty hands I use Dawn and some granular sugar as a hand cleaner. The sugar adds cleaning grit.Dawn will get the old black grease I describe off, but takes a good bit of work. So that's when I use the WD first, then Dawn....otherwise Dawn is always my "go to" hand cleaner as well. I keep a bottle of Dawn at my shop. Serves for hands, making solution for finding tire leaks, and mounting tires easier.
Will get rid of Scabies too.If I need the high strength I just dip my hands in kerosene
The only problem I have with many of the hand cleaners is that they leave my hands feeling dry and I noticed with prolong use of it it gets worse and I get cracking on the skin around my finger nails.I just use the citrus gritty gojo hand cleaner. Works awesome.
See thats why I switch to using Dawn I don't need to use a lotion or conditioner after washing my hands.I use that o'keefes working hands every day. My last position at work I was a mechanic every day, my hands would get so dry, callused and cracked that is hurt.
That stuff works great!
Try switching over for a month or so you may see some good results.
