Today I ran to town with the JD 2032 to fill up with #1 diesel for the winter. As I was pulling back in the driveway I remembered that I needed to grab the mail. As I swung around I heard something thump on the ground behind me. It was the five hundred pound weight on that had been on the 3 point. It was now hanging by 2 points as I had forgot to install one of the hairpin clips. Thankfully the weight is made from individual 30 pound weights and is easily disassembled as I bent one of the ears. First day I feel like being out this week and I have to break something.
Got back to the shop and removed the bent part and realized my Acetylene tank was almost empty. This is when I'm glad I have a carbon arc torch. Got that out and in no time things were straightened out and back on the tractor. I like using that thing and should use it more as it's easy to use, is extremely quiet, and is much cheaper than using the acetylene torch.
For those unfamiliar with this type of torch some photos are included. You adjust the carbons with the knobs behind the shield. The small connector goes in the welders stinger just like a welding rod. The ground hooks to the welders ground.
