Workin' on the Old Tractors
To my mind, it's amazing that those wobble joints can stay together at all due to the amazingly fast rate they run!
I would think they would have a larger outer bearing to handle the load. I just looked back at some pics when we bought this. It was 2016 and we used it for the first time in 2017. It held up for 8 years. Should probably pull the wobble box off ever 2-3 years and inspect it or just replace bearings as a preventative measure.
I was able to heat and drive the shaft repair bushing on the spindle today. Left it a little long and will grind it down to finished length. Had to polish it up with some emery cloth to get the bearing to fit again. It appears to be centered on the shaft which was a concern but I hope it works out. If not I think you can still buy a replacement wobble box at $1500 to $2400 depending on what all is needed. I'll get it ground and cleaned up this weekend and maybe even get it assembled if all goes well.
Trimmed the bushing down and now in the cleanup process. You can see how much damage to the threads this has but the new nut seems to hold well. I'm keeping my fingers crossed.
This is where I got to so far today. Need to notch the new taller castle nut deeper for the cotter pin to fit but then its time to assemble. I put a fare amount of pressure on the nut and it didn't strip out. The bearings for the other side still appear to be good so I will reuse those. I have one more bearing to replace that the yoke pivots on(pics on that later) and then its final assembly. Might get some rattle can to shoot on it.
Here is the yoke that does the wobbling. The lower pivot bearing had failed on this so I had to deburr some chew marks where it goes. This bearing has a locking collar that clamps down on the pivot pin/plate that was also chewed on and needed deburring. We will see how far I get tomorrow.
Made some more progress today. Loaded everything up with grease and assembled both sides on the spindles. Need to get another cotter pin the right size before installing the last cap. Then its just to bolt down the pivot shaft and set the locking collar and it should be ready to install on the machine.
I started working at clearing the concrete pad in front of the shop so I can park the Haybine there to get the wobble box installed and a few other repairs done before hay season. Moved a couple lawn mowers and still have one more under a tarp. The John Deere planter will go to the farm after I fix a flat tire. Then its just some tractor and farm equipment parts that need to be stored back in the lean-to on the container. There is also a John Deere BO under a tarp that needs to be moved.
If my DW saw hoard pile like that at my place, when I got home from work, it would be all gone to the scrappers.
Looks worse than it is and most of it is working. Both riding mowers run and the planter works but just needs a few new bushings. Lots of parts and pieces that belong to ongoing projects.
LOL....but I think Cjet said he wasn't married so no worrying there...
To tell you the truth I'd have a field day snoopy around his place...!
And more than half of this is my Dad's stuff.
Got the tire on the planter fixed. To save time I just fixed the flat spot on the bottom. ;) You don't see Allstate tires very often anymore.
Moved the planter up on the farm and cleaned up that half of the concrete pad. Just need to find a spot for the baler pieces and 2 power unit parts and I will have access to both of the big roll up doors again. For now this will get me a spot to work on the haybine which is my goal.
