I strip the plastic crap off the connectors and use heat shrink over them.Your right Kenny. I was thinking connector size. That tool does not using the insulated type wire connectors. Looks like the bare connectors with heat shrink. I normally use the insulated connectors with a bit of silicone to prevent corrosion. Going to check it out as I have a 25% off coupon.
I got out this morning and made some progress. Got new hinge point brackets made and new latch brackets. All clamped up and ready to weld where needed.
I came in to check wind speed before I start welding.
