Needed to free up some room in the shop, so I decided to break the Cub's tires down and store them till I am ready for them. I popped the bearings out of the front rims so I can source them. I wish all the tires I have done were this easy!
Trying to finish up the gas tank. It had a small dent that I repaired with JB weld, when sanding I found yellow paint. Checked the color brosure and sure enough it is supposed to be yellow. Not sure why this was painted grey. The Red Kote is still sticky in places. Thinking of useing an Acetone soak to try and remove the excess.
Made a mess, but for good reasons.
1. Oil needed drained any how.
2. Needed to know What type and how much, looks / spells like 90W, and around 4-5 qts.
3. Need to see if I can remove the axles (hopefully there are clips in the Diff)
4. Need to stand the frame on end (supported) to work under the chassis easier.
Productive day sort of. I finally got all the Red goo out of the gas tank, I sprayed WD40 in it to keep the rust at bay, it will stay like this. Got the frame stood up and supported (crap it is heavy!). I PB blasted all the bolts underneath, and took many detailed pictures. Done for the night.
Done for the night. Trying to remove this pin (has to be removed to get the frame off).
I jammed a small punch and broke the tip off it while heating with a braze torch..
I then hit my thumb with a hammer....... Air hammer.......With a pointed chisel bit.
Dang! I guess that hurt, Larry! At least you had a clean rag and a real band-aid. Last time I did something like that in my shop at least I had paper towels that were clean. Couldn't find a band-aid so a piece of paper towel and electrical tape had to work---LOL!
Well, it took all day and a $23 set of punches and a destroyed clutch disk (shame it was in such good shape) but the transaxle if off the frame now. Felt bad about the clutch so a new disk and through-out bearing has been ordered.
Tear down is mainly complete and parts are ready for pressure washing. I am leaving the Clutch / Brake pedal attached as there are no bushings to replace. First though I am waiting for the dew to burn off so I can mow the yard.
