I know, I spend too much time thinking of things to build. But this is one I have wanted to do for some time. A while back, I converted a Brinly 10" plow from a sleeve hitch to 3-point. It's in the middle of this pic.
I have a 10" Brinly sleeve hitch just setting there. And there is room on the plow beam of the 3-point for it to fit. Alice pulls a 12" with ease, so why not try 2-10" plow behind her. I will not cut anything on the sleeve hitch plow so it can be converted back easily. Mainly take the sleeve hitch off the front and use those bolts to attach. I spent most of yesterday reclaiming some metal for starting this. This morning I cut some pieces and drilled a few holes. The 2 short pieces in the next pic will be welded together to make the beam mount. The longer piece will get welded to that for the plow to bolt to. I know I'll need cross bracing between the plows, but need it semi set so I can figure those out. Member olcowhand gave me a distance from one plow point to the next of 19". I am going to try for a 9.75" spacing between the two so the second plow cleans the first furrow wall. It's gonna be long, just hope Alice can lift all this. I'm thinking so, but that's a lot of weight back there. Oh well, I can give it a whirl and see what happens.
