ShouldA question before I spend money for an ignition for this. Could I hook a 12V coil to the points and power it up to get it to fire off for a test run? Just wondering!
I don't have one of those resistor's on hand. May try without to see what happens! I have a couple more sets of points handy!Yes, you can fire them that way.
one thing to keep in mind, you will have some additional current draw through the points. Those points stay closed until they need the fire instead of stay open and then just snap closed and open... in other words, the points are closed 90% of the time instead of only 10% of the time.
I would suggest a dropping resistor like they used to have in the old Dodge cars in line with the coil.
There you go. A car type coil with internal ballast should do for what he's doingKenny, do you have a coil with internal resistor? Like one off an older Cub Cadet?
Got a 6 Volt battery. DonI don't have one of those resistor's on hand. May try without to see what happens! I have a couple more sets of points handy!
That's the coil I plan to use, off my CC 108!Kenny, do you have a coil with internal resistor? Like one off an older Cub Cadet?
I have already replaced that. Just may not have the sump filled yet!Most of the time it the diaphragm on those that goes out
No, they are 3/8" head with the slots cut across them. If you removed the tank, you can use a big screwdriver to get them out. I used an L-shaped screwdriver to loosen/tighten them!Kenny, were the bolts in the intake Phillips head bolts? When we were racing them we always traded those out for hex head 5/16" bolts and used a thin box end wrench.
