Hi, got the new spindle shaft last night so this morning got the deck reassembled with the new shaft and 2 outer drive pulley's and new belts, got the deck attached to the tractor got the mule drive belt installed and run the tractor for a test run deck was running smooth and quite so I tried mowing found the PTO clutch would disengage after about a minute (the Case has a manual clutch) so I attached a bungee to the lever and mowed for 1.4 hours it does a good job mowing but is much slower than my Suburban with which I can mow the same area in 1 hour. The Onan ran good with plenty of power and no noticeable oil usage but a pesty oil leak became appearent so will have to check that out and will have to adjust the clutch all in all its working
