I really like my 89 1620 PK its a nice tractor with 3 pt power steering and Hydro powered with a Kohler M20 20 hp twin, a couple of days ago it started running rough no power at first a was suspect of the carb but then tried removing one of the spark plug leads while it was running it just about stopped put it back on went to the other side made little or no difference when I pulled the plug wire got the inline spark tester and checked R side had intermittent weak spark so got it in the shop and started trying to get to the ignition module its impossible with the engine in place so I pulled the engine out to remove the flywheel cooling tin to get at the module, what a dirty mess ordered a new ignition module and washed down the engine its much better and the module is ordered as I said I like the tractor but working on it is a PITA.
