On my 58 Country Squire I've had the feeling that the old mechanical voltage regulator for the starter/generator was not working 100% the Ammeter needle would jiggle and at higher engine R's it seemed to stop charging. So I decided to install an electronic generator control / VR I've used these on another B&S with a starter/gen and they work great. Its made for Harley Davidson motorcycles PN is 74504-87, you have to cut the HD 3 prong connector off ( couldn't find one anywhere) an used insulated slip connectors made a mounting bracket to mt it to the side of the trans as I didn't want to fight with the hood at this time will in the fall. Mounted it connected the wires started the engine and happy days it was charging 15 amps on start up dropped back to 5/6 after a less than a minute had 14.6 VDC pull the lights on and the amps went up some and held its a keeper
