Hey guys,
I am in the process of getting my two Craftsman ready to sell, even though I am torn because I love the look and sound, but the barn can only hold so many tractors. And with a JD355D on the way....somethings need to go.
Well, I decided to fix the leaky oil sump gasket on my GT18 917.255910 and do a tune up. Oil has been slowly leaking since I got it, and I had the gasket on hand, so I did that. I put in a new battery and then I started to see smoke emanating from the engine shroud around the flywheel! I ripped the battery cables off and took a breath. I looked to see what I could, but to no avail. SO, I hooked up battery and tried to start the machine. Fired right up and no smoking now. I thought I was good. All of a sudden I see smoke coming from behind the panel! Disconnect again and I see that it is the Diode assembly coming from the stator that is fried. This is the second time. The first time it happened last year I chalked it up to age. Instead of buying a new $60+ diode assembly, I made my own. It worked fine all last year. So, to make sure I didn't kill the stator, I started up the tractor and tested the VAC coming from the stator, was getting 30vac at max throttle and around 24vac at low throttle. So, to me that looks to be in spec.
So, what could have fried the assembly? I short somewhere? I short in the stator, but why do I get good readings? A bad setup by me? I'm lost and need to fix this thing to sell it! Any help appreciated!
oh, and if I need to pull flywheel....advice because I couldn't get damn thing off last time I tried.
Here is some additional info and pics:
Tractor: 917.255910
part that is fried: 106315x
Diodes purchased for building new assembly: 10SQ045 10A 45V Schottky Diodes, for Solar Panel / Wind, Rectifier, 10AMP
Electrical Schematic: File attached :1003362-026
Alternator Setup: File attached 1alternator_id-004
Tri-Circuit manual:
Pics of old Diode assembly:
New Diode assembly (before current issue):
Tractor: 917.255910
Tri-Circuit manual:
