Cub Cadet LT 1050
I’m pretty sure I had this same model given to me in around 2013. I know it had the same motor. Same problem. Burnt up starter, valves out of adjustment and very hard to start.
The deck was shot. I put an eBay starter on it, adjusted the valves and it started right up. I didn’t keep it long enough to see if that starter held up. I put it up for sale and a guy came right away and wanted it just for the motor; his tractor was in perfect shape but a blown motor!
Seemed like a nice tractor for mowing!
Well I’ve had this tractor for almost three years now dealing with the PTO shutting off when mowing in reverse as a safety feature. It has a factory override switch to prevent this but it don’t work. I went on YouTube last year and a guy talked about cutting a wire above the reverse linkage but you have to remove the deck. This year I went back on YouTube and another guy mentioned just unplugging the white plug above the ignition switch. I done that and it worked. It’s so much more convenient mowing in reverse now.
Do this at your own discretion it can be dangerous.
My cubs had that switch also. Along screwdriver down through the slot, bent that spring switch out of the way and no more issues. me screwdriver will return the switch to operational again. Pulling the connector on the switch would be easier IF you can get at the connector. Both on mine were on GT's not LT tractors.
3 of my Cub Cadets had that switch. 2 were bypassed before I got them. The other one was after the first time I mowed with it. At first I thought there was a problem with the PTO, then I realized it only shut off when I went in reverse and it had the switch. As far as I’m concerned, that’s just unnecessary wear on the PTO. None of mine have an override switch.
After I would shut my PTO off and on several times in wouldn’t engage for a few minutes, so annoying. I read the relays get hot and also it can burn the clutch up.
