A few years back as a kids science project, we made a VAWT (Vertical Axis Wind Turbine aka Lenz Turbine) from long tongue depressors, 6X 2L tops, a few screws and a 1Amp motor. It worked like a dream. The kids got to see real energy created to light up a pack of LEDs. The VAWT took up half a kitchen table and was 3FT high. Example below:
Recently, I acquired a 4 pack of 12VDC 250W 3000RPM scooter motors. These can move a teen on a two wheel scooter up to 20mph for about a 30mins till the battery needs to be charged again. These are IP69K rated too.
So, I'm thinking about expanding my solar charging station that does the farm with additional wind energy. Seems like a nifty project for the summer.
I'll have to bench test the motor at various RPMs to get readings on Amp output. My system is limited to a 30Amp max input. This would also provide feedback on what blocking diode to select.
The solar works great by allowing the barns to pull power from the system vs. the power grid. Lights and electric fence zappers do well all year long. A little more juice to store could aid the system to run spot water heaters.
There are many VAWT plans to pick from. I hope to use plastic rain gutters and shape the air movers like below. It will require the use of a heat gun and a few shaping tricks to arrive at this clever looking device. If I make it so generic, the building code assessor would think it's just a weather wind monitor. And that's how I'm telling them because I will get feedback from the VAWT.
There are other plans, but a bit too overkill for my liking.
A and C examples are simple and good enough to build with satisfactory results.
I'm not the first to make a Lenz Turbine to make power. It's very popular in the EU. Doing am image search on the Lenz Turbine will give all kinds of hits.
A Lenz Turbine is designed to move FAST. The faster it turns the better the yield on the energy output. See these examples.
Being out in the midwest, the winds get gusty at night when solar isn't going.
