early 70s cast iron Briggs
no more leaking out the mouth, starts easy, builds up FAST (though the compressor that's there, is like a clown on a teeny tricycle even though it is only a single stage) would be a good one to piggyback a 2nd tank to for more reserve.
unloader works ok, cuts out at 120PSI, but it doesn't have the other stage. It either needs the head unloader or a clutch setup and speedup/idle down setup like my Emglo does.... If I kill the engine then want to restart before the air is used up, I have to drain the tank or I can't pull the engine over.....
small complaint though for the money and time I had to put into this.....
