HUH, did I get this right? This is a Ford Model-A tractor and your welded in pieces are Chevy bowtie logos.
Really nice work by-the-way.
They sure look like it don't they.
I like it looks like they were made to go thereI got this dash box off an old Allis Chalmers WD tractor.
This is mounted to the battery box.
Jd what do you use to do the soldering a large electric or a flame unit I have to say your solder jobs are outstandingI'm going to put the top center hose fitting from the Toro radiator onto this radiator.
However, there are indentations in the side of the tank on either side of the hole so there isn't enough flat surface to solder the Toro fitting onto.
I have made up a flat brass plate that will fit over those indentations.
The flat plate is soldered in place.
The old fill neck hole off to the right has been plugged.
The Toro fitting is soldered onto it.
The original bottom hose outlet fitting hole on the right side has been plugged.
A new hole is cut into the left side for the new outlet hose fitting.
This fitting is soldered in place.
There are two 3/8 diameter pins welded to the bottom of the radiator.
Those two pins fit into the rubber grommets on the bottom mounting plate to locate the radiator and hold it in place.
The radiator is painted.
I still have to put on the overflow tube and the fill tube fitting.
The fill tube fitting will go in the center of the top tank and it will line up with the fill neck hole in the old Toro radiator, which is now a radiator shroud.
