Been busy the last couple of days with the 100. I test mounted the motor and put the front axle on. got a new set of tires and rims for the front. the fit looks good . there is a slight downward rake to the front of the tractor now. I also painted and mounted the dash tower.
I took the motor back off and am in the process of mounting the floorboards in the new position and am going to try to use the original brake and clutch pedal with the hydro rear end. going to be a lot of trial and error to get it all working good.
Hopefully when it is done the only difference you will notice is no gearshift and the right side foot pedal.
