Kensico Trailer Add-on
chieffan
I been raking the little limbs and stuff into a pile than run it through the chipper shredder right at the pile. Have a coupel more trees to clean up under and be done. Then can pick up the grindings for mulch. A big pile of limbs don't make a lot of ground up stuff but it sure is a lot easier to handle.
Shotgun Wedding
Garlic Jedi
Sold one at the auction yesterday, very little use, 11hp Tech engine, good sized unit. $285. About what the engine alone was worth. Hustler 0 turn, 119 hours, very good condition , 60" deck, $3200.
I would not be without mine even though it don't get a lot of use but when you need it nothing will substitute for it.
Yup, a Fargo-Approved grinder/chipper sure come in handy....
holdenboy1960 (Shane )
I had a large pile of leaves/twigs to move. So I made some side boards for the Kensico. This thing will haul a bunch in it now. Being 5' long helps too.
View attachment 12147 View attachment 12148
Here's a brochure for these. Mine is the 235 Cart.
the hungry boards (sides) looks good on it , should paint it all mission brown to play the part of the trailer (old school look )
Shane
chieffan
Don't know the brand but our yard cart has tapered sides and especially the back. Heavy thick plastic. Changed the narrow wheels our for Cub Cadet front wheels. Rides much better now. Holds quite a bit. Stuff like leaves we pile on and lay a piece of plywood on top and a couple light weight straps onvr the top and go. Not as handy as Kenny's but gets us buy.
